Old 01-05-2008, 09:46 AM
DSmith DSmith is offline
Default Individual Wing Stand that will Rotate
Does anyone have pictures of a simple wing stand that I can build to allow me to handle the wing single-handed for painting, sanding, etc. I am building in a 2 car garge and space is limited so I can't put the wings on a saw horse and leave them set up. I'm getting close to the painting phase and I need to be able to roll them outside to wet sand, etc.
Danny
RV-7A
Old 01-05-2008, 10:16 AM
FrankK90989 FrankK90989 is offline
Default 2 X 4,s
Hi, I Painted almost every thing with these, below is a simple cross brace.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 01-05-2008, 10:24 AM
Default Fuse
on a roll (a pun) Spun like a "hotdog" had no problems.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 01-05-2008, 12:34 PM
photoadjuster photoadjuster is offline
Default simple wing stand
If you can find a copy of the video "From the ground up" you can see how they did it.
One end of the wing had a pivot, the other had a 12" x 12" piece of plywood attached that sat on a saw horse. You lifted that end and then rotated. You cut the plywood with 4, 6 or 8 sides so you have several choices of work angles. After lifting, turning and setting back down on another edge of the plywood, it will not turn until lifted again. Makes it fixed so it does not move while sanding, etc.
Regards,
Mike Stephenson
Old 01-05-2008, 02:16 PM
szicree szicree is offline
Frank,
Thanks so much for the pics. I am nearing this stage and really wanted a simple way to rotate fuse and wings. Also, that's some interesting landing gear you've got there .
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 01-06-2008, 05:30 PM
Thanks for the pictures Frank! That gives me the info I need to make up a good set of supports. Now to get all these little unfinished things finished then get on with painting.
Danny
Old 01-07-2008, 07:31 AM
jmartinez443 jmartinez443 is offline
Harbor Freight Rostiserie:
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 01-08-2008, 06:58 PM
dbuds2's Avatar
dbuds2 dbuds2 is offline
Default Thanks FrankK90989
Could you send a picture of how your 2"x4" attaches at the wing tip?
And are you already polishing your wing skin?
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
