GRT Sender Resistor Size
Does anyone know what size resistor came taped to the GRT instruction page with the senders? It's the one that gets put inline with an AUX wire, if you use that AUX for a pressure sender (i.e. fuel pressure).
There were two - as I recall, but I can't remember if they were both the same size. So if you know what the sizes are, please denote which one was with which page.
Thanks a ton!
Clayton Henderson
Beaumont, TX
RV-7 N454CH (Flying)
