Old 01-04-2008, 09:28 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Red face Help with Rudder Horn Brace R-710
There are tooling holes on the sides and the DWG shows an area to remove, the DWG does not show the tooling holes. See photo below.
I drew a line at the base of the holes and did a rough cut, but I can't see these holes in the DWG, do I trim until the holes are no longer there or leave half of the hole. I am worried if I trim too much there will be edge distance issues when the part is installed. The rivets in the flange of the lower rudder rib will go through this brace.
The second picture of the DWG shows the side view and how it relate to the lower rudder rib and spar.
Anyone done this part recently, I would appreciate any help and or picture you have.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 01-04-2008, 09:33 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
A lot of people have had edge distance issues here if they cut off the holes completely. Here is how I did mine, and it came out fine...
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 01-04-2008, 09:36 PM
Transporter Transporter is offline
Default Edge distance
Cut through the center of the holes (like Brad did) and you shouldn't have any problems.
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 01-04-2008, 10:52 PM
RVG8tor's Avatar
Thanks, It looks like my intial guess was not correct, thanks for the info. This forum is great
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
