Old 01-04-2008, 12:27 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Question Back Rivet set help
I bought my back-rivet set from Plane tools. I am now ready to rivet the rudder stiffeners but the nylon collar on my back rivet set does not allow the head of the set to hit the rivet square. Anyone with a set from Avery or Cleavland know if they do the same thing. I am trying to decide if I need to sand down the nylon collar so that the rivet set will hit square or buy one that is narrow. The vertical part of the stiffener is what interferes with the nylon collar. Thanks in advance.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 01-04-2008, 12:29 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default riveting problem
I'd call Planetools. If it's not right, I'm sure they'll make it right!
Don
VAF #1100, EAA864
-6A bought flying
Old 01-04-2008, 12:40 PM
Steve Steve is offline
Default modifications
I ground a flat on the side of the nylon collar on my ATS brand back rivet set so it would be centered over the rivets.
Steve
Old 01-04-2008, 12:50 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
I had the same issue. I ended up using the 12" set and holding the plastic against the surface with my hand, and got acceptable results. If I was going to do it over, though, I'd either grind down a side or buy one that's flat on one side.
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 01-04-2008, 12:58 PM
prkaye prkaye is offline
Default ditto on grinding it
I also ground the side of the nylon collar of mine flat, and use it all the time, no problems. Just be careful grinding it that you don't split it... use a scotchbright deburring wheel, not too much pressure, a bit at a time until it's enough.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-04-2008, 01:35 PM
Greg Arehart's Avatar
I have the same backset from Plane Tools, and ground down a flat side, about half the original thickness of the nylon. Has worked fine ever since.
greg
Greg Arehart
N 7965A
Old 01-04-2008, 01:54 PM
RVG8tor's Avatar
Default FYI new builders
greg
I ground down the nylon collar, hopefully this will help. I measured the Plane Tools collar and it has a approx. 3/8" dia. The Cleveland Tools advertises a 1/2" dia set, which looks about right. Avery does not list the diameter for their set but from the picture is looks smaller than the Plane tools set. Knowing Avery their set is most likely made to work with the stiffeners as well. You don't know what you don't know.
When I ground down the set I added a little radius at the bottom to match the inside of the stiffeners. Thanks for the help. grounding down the set I have seemed a better idea than waiting for new tools in the mail and it was easy on the Scotch Brite wheel.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 01-04-2008, 02:29 PM
Chappyd Chappyd is offline
You will find that there are times when you need to modify your tools to do the job you want. As most of the previous posters, I too ground down the nylon collar to fit the job at hand. I also bought an offset back rivet tool when I did the wings. I forget which one, but for one job I removed the collar and springs altogether.
Bucking bars are another place where mods are common, at least for me
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
