Old 01-04-2008, 09:20 AM
DaX's Avatar
DaX DaX is offline
Default Looking for PVC Rod-End Tool
I've searched and can't find it - someone did a writeup somewhere (maybe even on their build log?) for a fancy little tool they made from PVC to assist in installing rod ends into the control surfaces where they act as hinges.
I'd really like to make one for myself - if someone can point me in the right direction, I'd be grateful!
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 01-04-2008, 09:23 AM
Sam Buchanan's Avatar
been here awhile
Here is my version:
http://thervjournal.com/odd-ends.html#bearing%20tool
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-04-2008, 10:01 AM
jmartinez443 jmartinez443 is offline
Or if you want to put a few bucks ($16) into a nice tool instead you can get this from Avery: http://www.averytools.com/p-109-rod-...ting-tool.aspx
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 01-04-2008, 10:54 AM
DaX's Avatar
DaX DaX is offline
Thanks guys - that's what I was looking for. Didn't realize Avery sells one - I may just buy that.
Old 01-04-2008, 11:37 AM
gpiney gpiney is offline
I use a Gator Grip I bought at WalMart for less than $10. Works perfect without scratching up the bearings.
Best part is that it is a 3/8 socket and you can use it in tight places with an extension.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 01-04-2008, 12:22 PM
Radomir's Avatar
Radomir Radomir is offline
Try cleco pliers... already got 'em...and they grip the rod end "just right"
Radomir
RV-7A sold
Old 01-04-2008, 01:25 PM
WiseGuy WiseGuy is offline
Default Gator grip???
What's a gator grip from Wal Mart?
Old 01-04-2008, 01:38 PM
DaX's Avatar
DaX DaX is offline
That's a Gator Grip, and that's another fantastic idea!
Old 01-04-2008, 04:22 PM
TerryWighs TerryWighs is offline
DaX:
Follow link below and look under tools...PVC tool is very easily built. In fact, it was so easy, I took the time to waste...and painted it...
Actual instructional link was on Dan C. website....
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
