For about a year plus I have followed both of you and your build process. I want to thank you both for your help in this matter but also all the other bits of info here on the forums.
Jim, my build time line is almost part per part, process per process aligned with you. I think I will slow down just a bit to check out and learn from your build to the end........or maybe the race is on to the RV GRIN.
Thanks again
Frank @ SGU RV7A......ndy.....bgc........
Originally Posted by Jim P
Fran,
Just did the same. I used the upper right bolt on the SD-8 to the FW ground farm. Specifically asked my TC about that and shouldn't be a problem.
Jim
