Originally Posted by mark manda
anybody hear or know anyone using proseal or a similar product for filling in rivets?
Filling in Rivets? To hide them, no. It is too soft to sand, but why fill rivets. It is a metal plane and is riveted together. Be proud
If you want you rivet line to be less noticable, prime it, sand prime sand several times to fill it in with primer before top coat. If you have a dent body filler works. Some will use body filler to fill rivets but it adds weight and can crack. Again why, keep it light.
One use of proseal I did use for rivets is pop rivets. I injected the center with proseal (thinned a little with MEK). Works well and makes the pop rivets look like regular rivets. Again the idea is not to hide but fill the center hole.
BTW paint sticks to it very well. Cheers George
