Old 01-03-2008, 08:09 AM
prkaye prkaye is offline
Default right angle drill "attachment"
On my forward fuse I have some very tight places to drill. I need to get a right angle drill. On Avery, they have this right angle drill "attachment". What does this mean? Is this something I run with my regular air drill? Do I need to get anything else to make it work, other than some of the threaded drill bits?
http://www.averytools.com/p-552-mini...ttachment.aspx
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-03-2008, 08:21 AM
647jc's Avatar
647jc 647jc is offline
You may want to take a look at ACS 'TIGHT FIT DRILL KIT BOX' 12-01334 for $44.60. http://www.aircraftspruce.com/catalo...ill_kitbox.php . That's what I have and it works quite well.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 01-03-2008, 08:27 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default That kit is a great deal
If the attachment is made well, it is a great deal at $44 . A must have.........
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 01-03-2008, 08:28 AM
mannanj's Avatar
mannanj mannanj is offline
Default Drill
You attatch your drill motor to the shaft on the right side of the picture and a threaded drill bit to the angled end and drill away.
A one piece right angle air drill would be better but they cost a lot more. Unless you're going to be a repeat offender or you're a "tool junkie" this one should be all you need.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 01-03-2008, 08:30 AM
wow, great price on the one from Spruce... thanks! And Aircraft Spruce also now has a Canadian warehouse...cheaper shipping
Phil
RV9A (SB)
Ottawa, Canada
Old 01-03-2008, 08:32 AM
Mel's Avatar
Mel Mel is offline
I've built quite a few airplanes with this drill attachment. It works great.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-03-2008, 08:34 AM
mannanj's Avatar
Default Drill
If the one from ACS has a plastic gearhead like the one I used to have, I'd gladly pay the extra 50 Bucks for the one from Avery.
LAUS DEO
VAF788
Old 01-03-2008, 08:38 AM
Default deluxe?
ACS has a Deluxe version with a few more things for $57... worth the extra $13?
http://www.aircraftspruce.ca/catalog...fittoolkit.php
Phil
RV9A (SB)
Ottawa, Canada
Old 01-03-2008, 09:02 AM
flion's Avatar
flion flion is offline
A couple of things about the right angle drill attachment: definitely get the metal geared one. When you're working in a tight space, it's easy to bind up the drill bit, which will ruin the gears. Even with the metal gear set, I sheared the shear pin. Fortunately, the brand Avery sells is by a good manufacturer and they sent me extra shear pins for free. Very nice to work with.
One of the problems I had with the RA attachment is that it wants to spin instead of the bit. At first I used a vice grip as a handle for leverage but eventually I made a handle with a short piece of pipe and a hose clamp. If the bit binds up, the attachment will try to spin and you'll need more leverage than your hand can supply by gripping around the attachment.
Also, I ended up needing to make some cable runs through the fuselage that would involve holes drilled through the formers near the skins. There's a really long drill extension available (sold at Home Depot along with extension bits intended for running cable through a wall) that are fairly flexible. The extended bits are for wood, but the extensions are available for 3/16" and 1/4" shaft bits. The latter perfectly fit my unibit and allowed me to drill next to but parallel to the skins in several places. The extension is about a yard (sorry, it's at the shop so I don't have the actual dimensions or brand) and requires two people to use - one to guide the bit and the other to operate the drill motor. It changed the job from impossible to merely difficult. Well worth the $20 cost.
Old 01-03-2008, 02:44 PM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Default yup
bought mine today.. the deluxe version, and I added the collet adapter as well.... I've used it before (borrowed and did not want to give it back!!!) and loved it! it was an experience to drill with it... and to keep it straight. Its always wants to turn so it pays to get a good grip on it. Nothing beats the right tool at the right time.... Maybe if we could get some of these master tool makers to do a super small adjustable chuck for common drill bits that fits into the collet holder we'd be doing even better, anybody heard of such a thing?
Best
Brian Wallis
past the magic first 6 rivits and loving it!
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
