Old 01-02-2008, 04:03 PM
647jc's Avatar
647jc 647jc is offline
Default Alternator Blast Tube Cooling
I know this has been discussed in other threads but I don?t think a consensus was ever reached. Apparently it is felt that some alternators require additional cooling while others do not. I think most people (including myself) felt that adding a blast tube couldn?t hurt performance that much and better safe than sorry. However, I ran across another post in some other thread saying that installing an alternator blast tube in the plenum intake ramp as Van suggests would be like cooling your alternator with a garden hose, if you ever flew through rain. The alternator I have is the standard Vans 60 amp job (made in Japan label) and has an open frame design, probably for cooling purposes, and has a voltage regulator on the back also well ventilated. I really don?t think spraying water on it with a blast tube while it is running would be advisable and now I?m thinking no blast tube may be a better decision. So, as applicable to Vans 60 amp alternator with the open frame design and a voltage regulator on the back, what have other builders done and has anyone had any failures due to an over heated or a soggy alternator?
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 01-02-2008, 04:10 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I did put the blast tube in per Van's in my 7A. I haven't had any failures in 150 hrs and I have flown in the rain. I have the 60 amp alt supplied by Van's.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 01-02-2008, 04:21 PM
Default So you are Looking for Consensus?
Good luck with that. I have the 60 Amp Alternator with no blast tube 400 hours no problem. Blast tube holes do reduce performance and the faster you go the more they hurt it. If you are not looking for the maximum performance you wouldn't notice the difference. Roberta's experience should clear up the rain concern for you.
Bob Axsom
Old 01-02-2008, 04:28 PM
Bill Dicus Bill Dicus is offline
Roberta: You're using the internally regulated alternator from Van's, right? How did you provide overvoltage protection? Have been looking for a good method without success thus far. Glad the nosewheel mod went well. Happy New Year. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 01-02-2008, 04:30 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I ran my first alternator with no blast tube, and when the VR started to wander I put in a rebuilt unit, and decided to try a tube. I haven't thought about it since, and it's still running. When I looked at the unit closely, it looked very well "potted" to me, so I decided not to worry about the rain. I also agree with bob that stealing air from the plenum can reduce performance and cooling - but I don't know if it is quantifiable.
No blast tubes on my Mags though....and they looked GREAT at the 600 hour (should have been 500) inspection of the inerds...
Paul
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-02-2008, 05:42 PM
rvbuilder2002's Avatar
I don't think the automotive application for this alternator has any type of protection from rain, water, etc. Any time I have ever opened my hood after driving in heavy rain, the engine compartment is wet.
I install blast tubes on my alternators.
Scott McDaniels
Hubbard, Oregon
Old 01-02-2008, 05:45 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Its Your Dime
The original cheap, blast tube equipped 60 amp alternator purchased out of Van's catalog shot craps with relatively few hours on it. It failed both electrically and mechanically. See the link for pictures.
http://www.vansairforce.com/communit...t=11768&page=2
I replaced it with a Plane Power unit and am so satisfied, I installed one exactly like it in the -8 project. The installation instructions that came with the new Plane Power alternator states the following and I quote: "Install alternator per included drawing. Supply outside ram air to rear of alternator by the use of a 1" scat tube or other suitable ducting."
As always, the builder is perfectly free to either comply with or dismiss the recommendation.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 01-02-2008, 05:56 PM
Hey Bill!! Happy New Year to you as well. Yes, I have the internally regulated unit from Van's. I did nothing regarding overvoltage protection or regulation. Haven't had a problem with voltage, battery or any of the components. Voltage seems to be just right as is.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Glen L Torpedo
Old 01-03-2008, 12:44 PM
elippse elippse is offline
I have a 3/8" tube going through my cowling just ahead of the alternator. It will supply approximately 0.22 cf/sec of air at 200 mph. I don't think that this tube has a measurable effect on drag. The more of an electrical load you put on your system, the hotter the alternator will run. A lot of cowling designs will let air from the lower-half of the cowling go forward around the crankshaft and get pumped out around the back of the spinner. Since this is heated air, approximately 100F to 140F above ambient, it could add to the internally generated heat of the alternator as it flows past it. Plus, this air exiting the gap between the spinner and cowling is perpendicular to the flow from the spinner and causes a drag increase. Those in the know seal their crank opening to reduce drag.
Old 01-03-2008, 06:16 PM
Shockwave's Avatar
Shockwave Shockwave is offline
That doesn't seem like that much airflow. If my math is right that's 13.2 cfm. All but the slowest 60mm (2 1/2") computer fans can do that. A 1" opening would be 4.5 cf/sec (271cfm), or more than double the airflow of a 120mm computer fan. (or about 6 60mm fans)
If everyone is using a 3/8" opening I'll guess there's just not enough extra air to make a difference. Come to think of it, those are probably outside diameters, so the airflow will be even less.
Chanler Childs
RV-8A
Empennage complete
Building wings
