if you cant feel it then it should be good...mine had a line right down the middle just as you mention hit it with the scotch brite and still there. you can tell its a manufacturing mark. but i buit on
the alclad provide no strenth at all so if its not through the alclad then its ok.the alclad is .002 thick.call vans
