Old 01-02-2008, 11:03 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Cowl prep (pinholes) & camloc install - which first?
Will mounting camloc studs in the cowl now, make it more difficult to fill the pinholes later on?
In other words, should I do all the filling and sanding (at least where the camloc's go) before installing the studs?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 01-02-2008, 11:23 AM
szicree szicree is offline
The camloc grommets are easily removed, so it makes no difference which is done first.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 01-02-2008, 11:25 AM
Vern's Avatar
Vern Vern is offline
Default Camlocs
It's easy to hold the cowl together with clecos until final painting is done, then install camlocks.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 01-02-2008, 11:46 AM
Jim P's Avatar
Jim P Jim P is offline
Neither right or wrong, I did the pinhole filling first, then drilled for c-locs. I did need to remove the c-locs when I did some painting, and they are somewhat a pain to remove the snap ring (there's propbably a trick that I missed). Easy to go back on, though. I just think it's easier to do the bulk of the pinhole filling and sanding up front.
jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 01-02-2008, 12:18 PM
deene deene is offline
I'm at this stage on my 8...I went ahead and drilled for the camlocs since I wanted to have the cowling in its final position to determine the filling required.
I just used the studs with the gromets and didn't put the lock rings on. This means that the studs fall out when I take the cowl off and I have to reinset the studs when putting the cowl on.
Thus, with the cowl off and studs out, I can easily fill and sand...
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 01-02-2008, 04:13 PM
Rick_A's Avatar
Deene, great idea not putting on the lock rings since that was the real concern.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 01-02-2008, 06:42 PM
Gerald Clabots Gerald Clabots is offline
Default Gerry Clabots
I used some rubber o-rings to hold the fastners in place, Only put the metal clips on after the cowl was painted. I painted before flying.
I went to a supply house and bought a package with 50 in. About the same price as buying 2 in the hardware store. Bought one at the hardware store to determine the correct size.
Gerry
