Old 01-02-2008, 12:04 AM
tx_jayhawk tx_jayhawk is offline
Default Cylinder Baffle Connections
Is it correct to assume that you should NOT have the independent baffle pieces rigidly connected to each other in any ways (i.e. cylinder 1 and cylinder 3 pieces connected)?
It appears that the standard Vans baffle kit has the pieces "float". I was originally planning to attach my plenum top via a screw that goes through the overlapping pieces of the baffles, but I am wondering if it is inappropriate for those pieces to be connected together (given they normally "float")?
Scott
7A
Old 01-02-2008, 07:10 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default installation
i THINK they are not mechanically connectected so they can be installed in corners..otherwise you would not be able to install them..one could say they also were done that way for expansion. but remember that they are bolted to the heads very near each other. i feel certain that it would be fine to install a plenum on the top such as jeff bordelon (sp) did.
i dont know of any pieces that float they are all bolted on somewhere.
http://www.jeffsrv-7a.com/ENGINE/06-03-16.htm
William Weesner/ still kicking.
Old 01-02-2008, 09:07 AM
N131RV N131RV is offline
Default They should be separate
The cylinders move quite a bit relative to each other as the engine fires and as the engine warms up. Leaving an "expansion joint" helps keep them from cracking due to the forces imparted by the engine.
Scott
7A
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 01-02-2008, 09:54 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation They move!
Definitely. I recently saw a bad reconstruction of baffles on a Great Lakes O-360... the person (I won't call him a mechanic......) simplified things and riveted the two parts of the side baffles together. The arrangement is very similar to our RVs.
After less than 10 hrs. the rivets held, but the aluminum baffle cracked... the cylinders really do move with respect to each other....
This is one place to definitely copy standard practice...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-02-2008, 11:09 AM
cytoxin's Avatar
Default not advocating
using one piece on the side or bonding them together. just that many people have used the existing baffles and installed a plenum on top. such as jeff and others, the plenum PROBALLY still alows enough flex for individual cylinder movement. good luck
Old 01-02-2008, 11:39 PM
Shockwave's Avatar
Shockwave Shockwave is offline
Speaking of hard plenums, how would you attach them to the rest of the baffles so they don't leak and they don't crack? Oversize screw holes and rtv?
Chanler Childs
RV-8A
Empennage complete
Building wings
