Old 01-01-2008, 02:25 PM
CNEJR CNEJR is offline
Default Does Anyone Know if?
I am in the process of mounting trays & antenna's in my 6. My question is does the Garmin 430 "W" require a special antenna other than the GA56? Is there an updated antenna for WASS? Also if you buy a 430 new does it generally come with a GPS antenna?
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 01-01-2008, 02:43 PM
Martin Sutter Martin Sutter is offline
Super Moderator
The Garmin GNS430 comes with an antenna. The WAAS antenna is different from the regular 430 unit. At the antenna end the cable needs an TNC connector instead of a BNC, the tray end is a BNC like the 430. The cable must be RG400, RG58 is not acceptable (just had to change mine out for the WAAS upgrade).
Martin Sutter
building and flying RV's since 1988
