Originally Posted by RVG8tor
I am starting the rudder and have cut out the stiffeners to length. But each one has a slight bow to it. reading ahead it seems you check the rudder skin for straightness. Are the bow there on purpose to counter the skin, will the skin take out he bow? If seem the skin is thinner and will end to follow the bow in the stiffeners.
Is the -8 rudder matched-hole these days? If yes, you don't need to worry - when you cleco/rivet the stiffeners on, they'll straighten out. (I had the same issue on a -7 rudder and asked Van's about it).
If you don't have matched holes, you have to be careful to have the stiffener flat when you drill it to the skin. Once it's rivetted, it won't be able to bow again.
