  #31
Old 01-06-2008, 12:10 PM
JAT JAT is offline
In 1974 I checked out in the F-15A and flew it for five years before retiring. It had 50,000 pounds of thrust and only weighed 39,000 pounds at takeoff. At that time it held all eight time-to-climb records and some may even stand today. Think of this: 9,843' in 27.57 seconds, 19,685' in 39.33 seconds, 29,528' in 48.86 seconds, 39,370' in 59.38 seconds, 49,212' in 77.04 seconds, 65,617' in 122.94 seconds, 82.021' in 161.02 seconds and 98,425' in 207.8 seconds. With a 600 gallon centerline tank the bird would climb to 42,000' in twelve minutes and only be 40 miles from the field and do it with military power only (no afterburner). I very often cruised at 50,000' on cross countries at .98 Mach. That is about 10 miles/minute. I don't go quite as fast now, but I want you to know that the RV you are flying right now has the light, responsive feel of a fighter and you built the aircraft! If you are still pounding rivets keep at it. These RVs are sweet, even if they don't have a jet engine!
Jim
Old 01-06-2008, 02:56 PM
Kevin Horton's Avatar
Most of those records were later taken by Soviet aircraft, but the one for 20,000 m (65,616 ft) is still held by the F-15. The records up to 15,000 m (49,213 ft) are held by one of the prototype Su-27s, and the records from 25,000 m (82,021 ft) to 35,000 m (114,829 ft) are held by prototype MiG-25s.
The lower altitude time to climb records are even more impressive if you consider that the clock starts during the take-off roll when the aircraft first moves down the runway. The current record for 3,000 m (9,843 ft) is 25.37 seconds.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 01-07-2008, 06:22 AM
pierre smith's Avatar
Default Too old for risks.
Originally Posted by Paul Eastham View Post
Hey Pierre, here's a dumb question then -- why are you running a turbine in your Air Tractor then? Your average altitude is probably 100' AGL for the life of the aircraft. Need the extra power, maybe?Paul
Hope you're doing well!
Hi Paul,
The old 1340 cu. in. Pratts are so old and crack cylinders so often that it's become less expensive in the long run to run a PT-6. My old 1340 powered Air Tractor wouldn't hardly go 1000 hours without needing a $25,000 overhaul. My PT-6 has over 8000 hours and hasn't had an overhaul, just the CT wheel (compressor turbine) replaced...that and $1500 hot section inspections at 1000-1200 hours. I would have already spent $200,000 on overhauls on a 1340 in the same time frame. I also use 1 quart of Exxon 2380 synthetic every 30 hours ($9.00) compared to 2 gallons a day of Aeroshell 120 (60W) at $80 a day in the 1340. I sat down and did some serious math and the big winner, all things considered, the PT-6 won hands down.
I also had to park the old Air Tractor in a cornfield when the master-rod cylinder started shucking the lower cylinder skirt and the pieces internally beating the $$it out of the other reciprocating pieces....I'm too old for that
FWIW, the PT-6 is one of the few engines I don't mind riding behind at night!
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-07-2008, 06:43 AM
Ironflight's Avatar
VAF Moderator / Line Boy
That night crop-dusting has got to be a blast!!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-07-2008, 06:56 AM
Default No night ag..
......for me, Paul.......too many powerlines. California and Az are big on night ag, mainly because of high daytime temps and the associated chemical drift/evaporation problems during daytime ops. I do, however have a night-equipped Air Tractor...over 1 million candlepower with huge retractable lights...BTW, when one doesn't retract, it yaws the airplane 'cause it's out near the tip on a 50' wingspan.
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 01-08-2008, 01:02 PM
Eddie P's Avatar
Eddie P Eddie P is offline
Hi Pierre, I share your sentiments about the PT-6
The PT-6 engine was originally designed to run oil field pumps in Texas and Oklahoma, unsupervised, for days on end with no maintenance.
The best thing that ever happened to turboprop airplanes was the introduction of this "pump" to an engine mount. I've got many an hour with my life in the balance based on how well that engine performed. In over 4000 hours of PT-6 time I've got (8000 if you count 4000 with two engines)... I've never, ever had so much as a hint of quitting from that engine. I did see a very brief compressor stall one time, a momentary "BANG" in heavy ice (with ice protection in used BTW) followed by no more hint of complaints. I think she was just clearing her throat
Old 01-08-2008, 03:09 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Nothing's Perfect
The PT6 is a wonderful engine and a huge step forward over the old radials as Pierre points out. Night Ag ops? You ag guys have my total respect!
Like any engine however, PT6s do fail:
http://www.ntsb.gov/ntsb/brief.asp?e...19X01414&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...20X01419&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...06X01738&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...19X01415&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...04X01307&key=1
These are some single engine incidents just in the last year on C 208s.
I have a friend who suffered a power loss in a 208 as well with a sheared fuel pump drive. He just put it back down on the lake.
On the other hand, my dad has over 9000 hours in King Airs (18,000 engine hours) and only had to do one precautionary shutdown.
Very good engine but when you only have one...
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 01-08-2008, 03:27 PM
I'd love to see a reference for that "fact". All the info I have ever read says that the PT-6 was designed for aircraft turbo-prop applications first, and that other applications came later.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 01-08-2008, 03:39 PM
Dennis Madden's Avatar
Dennis Madden Dennis Madden is offline
3 shutdowns in 5000 hours with PT-6. But they were in BE-1900s that were used pretty hard. Still, enough reserve power in the good motor to make RTB a non event. Great motor. Would love to fly Pierres' ag plane when it's empty... ;-)
Dennis
RV-4, bought flying
RV-3B preview plans
HR 2 ???
Old 01-08-2008, 08:51 PM
Eddie P's Avatar
I never really gave much pause for thought to the well told Oil Rig story that a Beech Engineer told me several years ago concerning the PT-6 engine. The same story was also told to me by another guy a few years later - stuff gets around in folk lore I suppose.
But I wouldn't be much of a pilot if I didn't share in the skepticism when a fellow pilot raises the BS flag! The internet is an amazing place to research, but some of what you find can be an equally loaded mess. I did find a very good source on the PT-6 engine in the form of a published aviation history book though:
http://books.google.com/books?id=V0S...ay-w#PPA433,M1
Check out chapter 8 starting on page 443 - they later get into the talking about the DS-10, the fore runner to the PT-6, and then the PT-6 itself. I have not found any reference to an oil rig pump, but who knows. I'll consider the story as a likely folk lore "busted" myth unless I see otherwise now!
As far as the Wikki reference on the PT-6 engine, well, it's not quite all there, but close.
