Old 07-20-2005, 02:13 PM
Leonard_Smith_nz Leonard_Smith_nz is offline
Default Performance of RV6 with 83" FP prop
All,
Just daydreaming a little (at work!). I've chosen to equip my TMX-O360 RV6 with a Sensenich FP prop with 83" of pitch. I'm expecting an empty weight of around 1080 lbs.
Basic math tells me that I could expect a theoretical max speed (in knots) of 6.87 x RPM (in hundreds) e.g.
6.87 x 27 = 185 kts
Any aviation 'buffs' out there that can tell me the real world efficiency of propellers when mated with the RV frame. I appreciate that this is not an exact science, but then again, dreaming allows us a little latitude...
Regards,
Leonard
RV6 in New Zealand
Old 07-21-2005, 03:00 PM
Default Constant explained
All,
I've had a question as how I came up with the 'magic' multiplier in my previous post. No idea if this is correct, but my logic went as follows:
1. Prop pitch (meters) = Prop pitch (in inches) x 25.4/1000
abbreviated: Pm = Pn x 25.4/1000
2. Engine rpm = H (in hundreds) x 100
e.g. if H = 27 then engine rpm is 2700
3. Engine rps (per sec) = H x 100/60
In an ideal world every rotation of the prop will propel the aircraft forward by a value equivalent to the pitch, therefore:
Speed (in m/s) = (H x 100/60) x (Pn x 25.4/1000)
= H x Pn/23.622
to convert to knots: 1 (m/s) = 1.94384449 knots
Speed (in knots) = H x Pn/12.15
where:
H = engine rpm in hundreds
Pn = prop pitch in inches
for my RV6 with 83" of pitch running at 27 hundred rpm:
Speed = 83 x 27/12.15
= 184.4 kts
This is obviously an idealized situation. Any RV pilot with a FP prop should be able to tell me how far this figure deviates from the 'real' world. This should give us an (very rough) indication of prop efficiency as applicable to the RV airframe.
Regards,
Leonard
RV6 in New Zealand
Old 07-21-2005, 03:25 PM
N916K's Avatar
N916K N916K is offline
Leonard
I used your math and came up with 167.75 knots. That's a 79" prop at 2580 rpm. At that speed I can get around 163-164 KTAS. So with your math my prop is running at around 97%.
I'm not sure what prop you are thinking of running but some of the Sensenich props are limited to 2600 rpm.
What part of NZ are you living? I started my flight lessons in Wanaka in 1999. I ended up moving to Wanaka a couple years later. Sure wish I was back there with my RV. No more spiralling to get out of Milford Sound like in the 172.
Cam
Cam
Santa Ana, CA
RV-9 at KFUL
Old 07-22-2005, 01:27 PM
Default New Zealand
Hi Cam,
I'm on the Kapiti Coast, about 60 north of Wellington. Yes, NZ is a great place for the RVs. From where I am I can just about fly to every airport in New Zealand (with the possible exception of Steward Island) non-stop.
It's for that reason, and the fact that NZ is very mountainous, that I've chosen to go with the 83" as opposed to the Van's recommended 85". Now I'm trying to figure out how much the fewer 2" will cost me in cruise.
Your numbers look a bit high. I recall reading somewhere that the efficiency is in the order of 85% (but my memory is vague on that one).
Be sure to give me a shout if you come to NZ again...
Regards,
Leonard
RV6 in New Zealand
Old 07-22-2005, 02:28 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Originally Posted by Leonard_Smith_nz
Hi Cam,
Regards,
Leonard
RV6 in New Zealand
Leonard,
This is somewhat more direct than your approach but if you are interested in only the difference in cruise speeds and assume similar prop efficiencies between the 83" and 85" pitch, then cruise speed with your 83" will be equal to the cruise speed of the 85" times 83/85.
Or a reduction in speed of about 2.4%.
If the coarse pitched plane is clipping along at 165kts, you could expect ~161 kts for the same RPM.
-Mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
