Originally Posted by fdarby
Thanks Jeff and Bill for your reply. Bill the stiffeners are riveted in and there is a cleco in every hole around the perimeter. You can not see the bow by just looking head on at the trailing edge,but you can when you sight down the edge from one end to the other.
A small bow should have a negligible effect on structural strength, aircraft handling, or performance.
I'd not worry about it until you get to the end of the project. If at that point you still have hopes of building an award winner, then make a new rudder. If you, like most of the rest of us, have collected enough small glitches that you've given up on any major awards, then simply fly the aircraft as is, and kill anyone who dares to sight down the trailing edge of your rudder.
