HS Rivets
Mike,
I checked rivet length before driving/squeezing. In a couple of cases I used a rivet cutter to cut some 'custom' rivet lengths. In general I was satisfied with Van's rivet call outs.
I'd ask yourself whether a given rivet will be strong or weak. Obviously, you want to keep the strong ones and get rid of the weak ones. A rivet that's well-formed (good shop head, proper diameter, etc.) but is a little tall will still be a strong rivet and I'd keep it. The big danger with a rivet that is too long before driving is that the shop head will clinch/deform so if it hasn't deformed it will be fine.
If you've got a bad rivet (clinched over with a thin shop head on one side, cracked, etc.) then obviously you should fix it.
Consider marking rivets you're not happy with using a Sharpie as you rivet. If they still look bad to you the next day, do them over or get a second opinion. They won't get any worse over night-but don't build so far that you can't get to them the next day!
Good luck!
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
