Old 12-27-2007, 06:30 PM
markscogg markscogg is offline
Default Rigging the elevator pushrod
How do you rig the elevator pushrod running from the rear control stick to the elevator bellcrank. (F-440 in my case) It has to rotate +/- 20 degrees or more with aileron movement.
It doesn't seem like the rod ends have that much room to move once they are locked down with the jam nut.
What am I missing here?
Mark Scoggins
Charlotte, NC
RV-6 bought,flown and sold.
Rv-4 bought, flown and sold.
Old 12-28-2007, 08:23 AM
DGlaeser DGlaeser is offline
Default Small OD washers . . .
On my 7A, the plans call for small OD washers (they look like metal O-rings) on either side of the rod ends. The are a pain to install, but they provide a wider range of motion.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 12-28-2007, 10:59 AM
Rupester Rupester is offline
My 9A plans call for the same shiny/teensy washers. And as been said, installation of same is a royal PITA!
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-28-2007, 07:07 PM
Default Tiny washers
Van's has them. They are 'WASHER 5702-75-60', eleven cents ea.
Add the crating and shipping charge, and I will have some very expensive washers. Won't get here until next Thursday, what with the weekend and holiday.
Thanks for the help.
Mark Scoggins
Charlotte, NC
