Old 12-27-2007, 08:55 AM
pierre smith's Avatar
Default Catto rear plate loose.
Mornin' all,
I was busy loosening my prop bolts this morning in order to add a spacer behind the front spinner plate. When I took the prop off, the rear prop plate, which came bonded to the prop from Craig, fell off. Is this any particular problem? I was simply going to put it back on the flange bushings and add the prop and go fly.
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-27-2007, 11:01 AM
newtech's Avatar
newtech newtech is offline
Hi Pierre, can't help much here as Craig just called about a week and a half ago to tell me the wood for my prop had been cut. It is supposed to ship around the middle of January. First flight looks like late March so I need to be talking to you about transition training in the late February, early March time frame. Will PM you next month to get a date firmed up.
Steve Eberhart - RV-7A, O-360-A1A, slider, Grand Rapids Sport/HC and a whole bunch of Kandy Apple Red paint.
Old 12-27-2007, 12:26 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default My opinion
Not a problem. If it is there as a spacer/crush plate it will still serve that function. If in doubt call Craig Catto.
