Old 12-26-2007, 07:35 PM
asu4me asu4me is offline
Default 5 point Crow Harness question
I'm installing the Crow 5 pt harness. What far apart do the crotch strap attach brackets (that are mounted between the floor ribs) need to be to accomodate the crotch strap mount?
I know that it's 1/8" when using the Van's set and slightly wider if using the Hooker Harness...not sure how to space the brackets for the Crow set up.
Thanks guys.
Jerry Kosirog
Mesa, AZ
RV-7A Flying Phase 1
N855GK
rv74me@yahoo.com
Old 12-26-2007, 07:54 PM
captainron's Avatar
captainron captainron is offline
http://www.vansairforce.com/communit...ad.php?t=21562
I used 5/16" spacing and drilled the anchor bolt hole to 1/4", but haven't decided on a harness brand yet.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 12-26-2007, 09:45 PM
Rockyjs Rockyjs is offline
Unless your Crow Harness is different than mine, 1/8" spacing between the plates worked fine. I also used 1/4" holes and specified this when I ordered my harness. They are very well made.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
