Old 12-25-2007, 09:49 AM
larry G larry G is offline
Default Aileron spar?
I'm working on clecoing the leading edge skin and the trailing edge skin to the spar to match drill. I come across the problem of the spar has quite a curve to it. I can cleco the top fine but the bottom when I pull the leading edge back to the spar it makes the curve worse. I cant line up the holes. Do I have to flute the spar or is this not good thing to do.
Old 12-25-2007, 10:24 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
What airplane are you building, Larry? Are you saying that the spar is warped, even before you attach anything to it? That doesn't sound right...Van's does make reject parts on occasion...
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 12-25-2007, 10:43 AM
I'm building the RV-7 I tried to insert a picture could not get it to work
Try this http://img178.imageshack.us/img178/2...ronsparjb7.jpg
Old 12-25-2007, 11:14 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Try starting with clecos at one end (top and bottom if nessesary), and pull the spar into alignment as you go. And don't flute.
This keeps everything straight as you proceed, as well as a bit of leverage to move the spar end fore & aft until holes line up.
L.Adamson -- RV6A
Old 12-25-2007, 03:08 PM
tamoell tamoell is offline
Default Aileron Spar
Larry G.
I reviewed my log entries and I don't recall having the curve in the spar shown in your picture. Everything fit and was straight. No pulling of components into alignment....
I am with L. Adamson and I wouldn't flute the spar. Not without having a Q&A session with Van's....
Todd Moeller
Former RV-7 Builder
Buckeye, Arizona
Old 12-25-2007, 09:06 PM
GAHco's Avatar
GAHco GAHco is offline
Red face I had this.
When I built my first aileron on my 6, very similar aileron to the 7, this happened to me because it was sitting on the bench and I assumed it would stay straight as I tucked it in and drilled the holes. WRONG?
When I took it out to de-burr the spar went back to straight but the holes were in a curve.
Silly me, I should have known better than to make any assumptions.
When the new spar came in I REMEMBERED to use my edge distance marking tool that I made to accurately mark the cent line of the spar.
It is a piece of wood with a super fine sharpie and an adjustable stop.
I marked two lines about 1/16" apart in different colors.
You may not actually be drilling in the exact center of the spar, but with the marks you will get a very good idea if its straight as you go
My second attempt came out straight and beautiful.
I am glad I messed up early in the game as it helped me be more patient and careful with the resat of my project as I still go along.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 07-29-2008, 03:27 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
I had this problem too and contacted Gus at Vans Support. Here is the item in my build log with some photos on how to resolve it quite easily:
http://www.mykitlog.com:80/users/dis...og=60519&row=1
Bob Ellis
UK
RV-8 wings nearly complete
www.rv-8.co.uk
