Old 07-18-2005, 03:22 PM
johnp johnp is offline
Default Torquing jam-nuts on rod-end bearings.
i know a lot of you just go for the "german torque" here (guten-tite), but i wanted to try to torque them. here's what i came up with.
i got a set of offset box-end wrenches (cheap, from harbor freight). i took the 9/16 and cut a gap in it so it would slide around the bearing, then i could put it down on the jam nut. but before i did, i drilled a hole in the handle, 5 inches from the center of the box. i also picked up a couple of fish scales from academy -- one is 0 to 20 pounds, the other 0-50 pounds. with the jam nut finger tight, i put the wrench on it, hooked the fish scale (spring balance) into the hole, and pulled until the balance read 35 pounds. i figure that's 175 inch-pounds. [i sure hope that's the correct torque for those buggers -- the thread is 3/8" diameter, and that's what the torque guide in chapter 5 says for 3/8 -- 160 to 190.] so, it might not be as accurate as a real torque wrench, but i figure it's alot closer than wingin' it.
the offset on the box-end was about an inch or so -- not enough to clear the rolled edge (i was doing elevators), but enough to clear the skin as it sticks out past the spar.
john prickett (VAF 449)
manchaca, tx (suburb of austin)
rv-7a finish kit
N337JP (reserved)
Old 07-19-2005, 12:27 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is online now
Anyone try torquing the jam-nuts with a crows foot and torque wrench?
I understand that there are some calculations you need to consider, but I haven't researched this yet.
-Mike
RV-8 Fuse
N468RV
Old 07-20-2005, 06:25 AM
Thermos's Avatar
Thermos Thermos is offline
Mike,
That's how I tightened the jam nuts on my elevator and rudder. Worked fine, and the equation is pretty simple. Check out this website -
http://www.engineersedge.com/manufac...e_wrench_1.htm
for a good description of the process and a torque wrench extension calculator. Dan Checkoway also has a calculator on his website.
John,
Those jam nuts are AN316 shear nuts, and I think they have a lower torque spec than normal AN365 nuts. The Standard Aircraft Handbook has a table for both types, and if I recall correctly 3/8" AN316s only get torqued to 90-110 in-lbs...but check me on that - I don't have the book in front of me.
Hope this helps...
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 07-20-2005, 07:55 AM
John,
Hope this helps...
Dave
thanks, dave. i've got one of those books somewhere -- couldn't find it, so i went with the info i could find in chapter 5 of the van's manual. i'll do some more digging and find that book and check it out.
john
rv-7a finish kit
N337JP (reserved)
