Im to the stage of installing the brake lines and brake hoses in my 9A. My questions are rather straight forward.
1st - What type of "dope" can you put on the AN fitting threads. I know for the fuel line fittings, I used "fuel lube", and I was told NOT to use this for brake fittings.
Obviously when it comes to putting together the nylon fittings and tubing, NOTHING is used, CORRECT ????
2nd - Im thing about making my own brake lines rather than use Van's pre-made lines that go from the rudder pedal to the firewall support. I want to use Aeroquip hoses, but not sure if I should get Aeroquip 701 SS, which is used for the fuel lines, or go with Aeroquip 666, which is a medium pressure Teflon hose with SS outer cover !!!
Any help or suggestions welcome
Hank
Pittsburgh, Pa
N918HB (reserved)
