Old 12-22-2007, 05:46 PM
8CW 8CW is offline
Question Name That Label Maker
Does anyone know what labelmaker may have produced the these heatshrink labels, and also what the heatshrink may be called. These are about the best looking labels I have seen. It is the fourth picture down. I have tried to find contact information for "Jim" on his website, but can't find any. Thanks!
http://home.comcast.net/~jwdweb2/Wiring2/wiring2.html
Bill Settle
RV-8 N38CW (Reserved)
Old 12-22-2007, 05:53 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I dont know where to get that done, but you can get clear heat shrink, and make paper labels on the comp, just put the paper on the wire, and cover with the clear shrink tube.
http://www.bandcspecialty.com/cgi-bi...58218#s816ckit
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-22-2007, 05:54 PM
Jim P's Avatar
Jim P Jim P is offline
Default It's a Kroy
Check the Kroy website. They make a variety of printers that print on heat shrink. Not real cheap but works great.
jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 12-22-2007, 05:59 PM
N131RV N131RV is offline
Default K-Sun
I did not look at the picture, but I used a K-Sun LabelShop2001xlst to do all my wire labels.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 12-22-2007, 06:31 PM
pczar3's Avatar
pczar3 pczar3 is offline
Wink I used a Brady
I used a Brady labeler but the cartridge of shrink tube was expensive. Later I found the good old permanent markers we use when laying out the aluminum when written on a piece of regular heat shrink tubing will shrink down and is very durable. I use white heat shrink that I bought from Digikey, or Radio Shack or Fry's electronics. Write the wire name, slip it over the wire, and shrink it.
Hope this helps,
Paul
pczar3
N694BP reserved
Old 12-22-2007, 06:35 PM
RV8MW RV8MW is offline
NOT SURE BUT LOOKS LIKE IT WAS DONE WITH A DYMO RHINOPRO WITH THE YELLOW SRINKWRAP
MIKE WARREN
RV8 N184MW RESERVED
TMX-IO360 REDGOLD,HARTZELL CS
CLINTON N.C.
www.mykitlog.com/mwarren
Old 12-22-2007, 06:43 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
I'm pretty sure they're heat shrink labels from Dymo RhinoPro 5000. That's what I use and mine look identical.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 12-23-2007, 06:02 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Guy
Guy,
Oh Yea! That sounds like the tool I could REALLY use at this point. Where is a good place to get a Dymo RhinoPro 5000 and the suitable heat shrink required? Also for wires already run and hooked up, is there a suitable method to wrap labels around the wire?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-23-2007, 06:58 AM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Rhino Pro
I agree. These appear to be printed on a Rhino Pro. I bought mine on Amazon.com.
The heat shrink works very well and comes in a few different sizes. A bit costly but well worth the money as the end result looks extremely professional.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
Old 12-23-2007, 09:10 AM
Originally Posted by Rick6a View Post
Guy,
There is a suitable method to wrap labels around the wire. The RhinoPro comes comes with (and has available) very flexible vinyl labels just for wiring. I use the heatshrink tube at the ground and fuse block ends (the heatshrink is expensive) and then use yellow lables wrapped around the wire about every 5 feet along its length. I started with white labels, but they're too hard to see on the white wire. The labeler has settings for wire all the way from 22AWG to TV Coax. You just tell it the wire size and it spits out the labels.
I got mine for Christmas last year, the Mrs. says it came from http://www.cableorganizer.com. Don't bother with an AC adapter, mine has been running on the same set of batteries for 363 days now.
Guy
Guy Prevost
Albuquerque, NM
