12-20-2007, 01:00 AM
Combining grounds for several circuits
I'm thinking of combining grounds for several circuits and running one
ground back to a forest of grounds behind my panel; namely landing and position lights and pitot heat. I was reading 43.13b chp 11 sec 5 and only
found references about single point of failure, but no other recommendations unless I missed something. I know about using the airframe for ground and running individual grounds. Any Opinions about this being a totally wrong thing to do?
David Brenegan
RV-8, Fuselage
12-20-2007, 04:53 AM
David,
The lights are not a high noise application, so you could probably get away with it.
On my -9 I riveted a plate nut on the outboard wing ribs and grounded the position and landing lights out there. Everything else, with the exception of the strobes (documented on my web site) were run back to the common ground on the firewall.
Regarding the single point of failure thing...
Should that wire break, it won't comprimise the safety of your flight, other than landing without a landing light and we (at least I was) were trained to do that back when we were getting our PPL's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-20-2007, 04:57 AM
extra wire
I'm doing much the same thing, with at least 2 different large conductors (one to airframe, one to batt -) to ground for redundancy.
james kleen
savannah
RV8sp - RV3
12-20-2007, 07:53 AM
Loads out in the wing or tail that are not noisy should simply use the airframe as ground. Just fasten the ground wire to a loop connector, scratch the primer/anodizing off, and bolt with a star washer.
I guess there is only one airframe, so no redundancy though....
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
12-20-2007, 08:18 AM
James,
This may introduce noise into the system, if a ground for one circuit goes to both locations.
Bill R.
SC86 - Easley, SC
12-20-2007, 09:56 AM
Just make sure that the one ground wire is large enough to carry the TOTAL current for all circuits for which it is serving as a return. Pitot heat and landing lights are pretty power-hungry. Also, you'll have lower stray magnetic fields (affects heading instrumentation) if the return wire follows the supply wire fairly closely.
Miles
RV-7 TU 904KM (reserved)
Construction Log
12-20-2007, 10:02 AM
That was my plan... size it accordingly and run it back in the same conduit.
David Brenegan
RV-8, Fuselage
12-20-2007, 10:21 AM
OK...
Originally Posted by N941WR
James,
Yes... but not with the specific circuits mentioned... gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-20-2007, 11:06 AM
I'm not sure how pitot heaters control temperature, or even if they do. If they are full on all the time, or have proportional control of the current, they will not induce a siginficant amount of noise. If however they have an ON/OFF thermostat, they would generate some electrical noise.
Construction Log
12-21-2007, 06:08 AM
Why not use the airframe?
Why would you run ground wires when the entire airframe is made of aluminum? Did you read somewhere that the airframe is a bad ground?
Take it from a former Air Force avionics technician. Wires break and they're a bitch to troubleshoot. So if you use the airframe for your ground, right off the bat you eliminate half the wiring in your airplane. How can that not be a good thing? Not to mention the weight you save.
Jon Baker
RV6A sold, RV4 in-progress
Houston
