Aussie 9A (Fred),
I see from your profile that you are building a Quick Build. The only major components that you will have to rivet together are the empennage, canopy etc. Most of the priming work has already been done for you in a QB Kit so IMHO you may as well build the remaining components to a similar standard to the QB components ie; fully prime all parts and rivet them together without any extra type of sealant. I have no experience with the wash primer that Vans uses on the QB kits. I used a 2 part epoxy primer and am very happy with the results in terms of weight and apparent corrosion protection. Contact me if you want details of the primer (available locally in Australia) that I used.
Fin 9A (Slow Built)
NSW, Australia.
