I would remove that particular primer if it were me. If you had used a good epoxy primer and good prep than I would have said it would be ok. The adhesion of the sealer is only as good as the paint and the solvents in the proseal will probably soften your primer. The self etchers don't adhere that good anyway in my experience and are easily removed with many solvents.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
