Originally Posted by markscogg
Know anywhere else to buy just the ring?
www.eci2fly.com has the part for around $105.
Their resellers (J&J Airparts locally to me) sells it for $78.00
The Superior part was $3.00 cheaper, but OOS.
Call ECI or go to the website and get a list of resellers.
BTW, if your ring gear is rough, your starter pinion is probably not too snazzy either.
Having just replaced my ring gear and starter due to damage from a kickback, I feel a bit experienced.
Since I have Bendix (not slick) mags, it appears that in cold weather (dry air, etc) the Bendix will make enough spark on the right mag (while cranking) to contribute to kickback. The first kickback was enough to snap a tooth off the ring gear. I foolishly flew the plane a few more times, furthering the damage.
Lesson learned.
To prevent kickback, I wired in a jumper on my ignition switch that kills the right mag while the starter is engaged.
Just FYI.
