Old 12-17-2007, 08:33 AM
tx_jayhawk tx_jayhawk is offline
Default Ground Power Solutions
I am curious what solutions others have employed for providing ground power. I'm assuming some have used the standard piper jack, but I'm guessing there may be better ways to do it. If you have used a jack, where/how has it been incorporated?
Anybody have any creative way to share? The cigarette lighter is always possible, but mine will be limited to 10 amps. I'd like to have the ground power capable of more than 10 amps.
Scott
7A
Old 12-17-2007, 04:50 PM
kcameron kcameron is offline
Why more than 10A? You should be able to go to about 20A with a cigarette lighter socket if that helps.
I just pulled out the Cessna-style three prong ground power plug on my RV-4. I saw it as significant weight which should never be needed. I'm going to start carrying one of those cigarette lighter-based "jump" start systems. That way, if I should leave the master on or something, I can get a jump from any passing car.
Kev
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying
IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
Old 12-17-2007, 05:31 PM
AlexPeterson's Avatar
Great idea, cig plug on both ends. Just be sure the car supplying the juice is running. And, make sure you disconnect it before trying to crank!
It could have pigtails (normally capped) for connecting to a standard charger. Gotta make one of those.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-17-2007, 05:56 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Yep... one set up with the cigar lighter on one end and the Tender Plug on the other and I will also carry the Tender Jr., a very small $23.oo unit in the tool kit.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-17-2007, 06:26 PM
videobobk's Avatar
videobobk videobobk is offline
Don't have a picture of this, but hope I can explain it. Just inside the oil door we have a standard 120v type cord socket wired directly to the battery with #10 wire. I carry a plug in the plane with #10 wires coming out of it, one red and one white. Need power, open the oil door, plug in the short cord (only about a foot long) and hook up the cables to a charger or battery. One wire is longer than the other to help keep the cable clamps apart. Weighs a couple of ounces, cost less than $10, and works every time someone sneaks in and unlocks your plane and turns your master switch on. Something like that, anyway.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 12-17-2007, 06:36 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Smile Ground power solutions
I have a cig power plug mounted on left side sub panel where pilot can reach under and access it. That power plug has a circuit breaker mounted next to it. Plus lead from power plug goes to circuit breaker and then to plus terminal of battery. With this access to the battery, I can put a charger on the battery if I need to run my panel in the hangar, or WHEN I do have a battery issue in the future (probably due to me leaving master on).
Works for me.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 12-17-2007, 06:37 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Has anyone ever tried to jump start through a cig lighter? I wouild be very leery of passing even 10 A through such a device if you want minimal voltage drop and heating. Of course, if you are actually driving a real cig lighter, then you want it to get hot.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 12-17-2007, 06:51 PM
As stated above, you would not want to leave this the cigar lighter cord plugged in when actually cranking the engine. You will be surprised as to what 15 minutes of charge will do for the battery if has not been drained over night.
Reiley
VAF# 671
Friend of the RV-1
Old 12-17-2007, 07:07 PM
AltonD's Avatar
AltonD AltonD is offline
One thing to consider:
The master solenoid is powered up from the battery side. If the cig lighter is on the bus side and the battery is too low to close the solenoid, no charge current will reach the battery.
Now way could you crank an engine through the cig lighter. At best, you can charge up the battery and then crank off the battery. I am guessing, but cranking an engine might pull greater than 100 amps.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 12-17-2007, 07:15 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
The master solenoid is powered up from the battery side. If the cig lighter is on the bus side and the battery is too low to close the solenoid, no charge current will reach the battery...
I have my cigarette lighter wired directly to the battery for this reason. It works well for charging the battery.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
