12-15-2007, 07:01 PM
"Safety Trim" Intelligent Servo Controller
I'm gonna jump on the group buy.
...but can you guys with flying RVs share your opinions on single axis vs. dual axis? Is dual axis that important?
I'm guessing that the dual axis is used when hand flying the plane, while a wing leveler autopilot will keep the wings level on long flights? Does that sound correct?
I'm just wondering why, if the dual axis is important that people are buying the single axis.
Lance
12-15-2007, 08:36 PM
Hmmm... The other axis, roll, is used for aileron trim. Even if you have a roll servo for the autopilot, you shouldn't be relying on it for trim. In a side-by-side, roll trim is quite useful (understatement).
Scott Card
CMW E-Lift
12-15-2007, 09:42 PM
Why do RVs use aileron trim, and not rudder trim?
Ralph Finch
Davis, N. California
RV-9A QB Log
12-16-2007, 06:00 AM
unqualified unfluencer
Tanks in wings. You empty them one at a time, and as they empty the roll axis trim is changed.
b,
d
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Part time: Supporting Crew Member CAE Embraer Phenom 300 (E55P) @ KDFW.
- Occasionally: Contract pilot (resume).
12-16-2007, 07:21 AM
Fence Riding
I almost replied for one, then reality set in. I probably won't need one for a few years, since my wing kit isn't scheduled to arrive until February.
But the offer is pretty good. So my question is: will this still be a good purchase 2-3 years from now, or will better technology come along before I complete?
12-17-2007, 03:03 PM
I can't speak for other planes but my RV-4 requires significant roll trim changes depending on airspeed. The ball is almost always centered in steady state flight.
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
