preheat
I crank up the preheater at 32 degrees. If the temp reached freezing or below in the last few hours I preheat until the oil temp gauge reaches 40 degrees.
I have a sump heater that will be plugged in on a timer the night before launch and a red dragon propane heater to warm up the jugs.
If the temp is only supposed to get to 30 degrees or so a 100 watt trouble light with metal cage and a blanket over the cowl should keep the engine nice and warm.
