Old 12-13-2007, 04:20 AM
NYTOM NYTOM is offline
Red face Need a little advice here on "AOA's"
Has anyone installed their "AOA" sensors in the same wing rib bay as the landing light? It would make any service on them easier with the tip removed but I was wondering if there's some unseen problem here. Also the plans state not to install them too close to the wing tip but don't give any minimum dimensions. I'm planning on installing the light on the outside edge of the bay and the sensors on the inside as far from the lens as possible. Do you think I'm good to go?
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 12-13-2007, 04:57 AM
plehrke's Avatar
plehrke plehrke is offline
Default Good to Go
That is exactly like mine are installed. I have no problems with the AoA being influenced by the landing light. Airflow is pretty streamwise and therefore it is OK.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 12-13-2007, 08:55 AM
Jekyll Jekyll is offline
I exchanged emails with Rob Hickman about this issue on my 7A. He said NO PROBLEM putting the AoA probe behind the Duckworths light.
Jekyll
Old 12-13-2007, 12:09 PM
N908RV's Avatar
N908RV N908RV is offline
My friend's -8 has an AOA port installed in his outboard bay near the tip and he has a Duckworks light there as well. I had the opportunity to fly his -8 and try out the AOA. It worked as advertised, no problems at all.
Other than that soothing voice screaming at you in the flare as you stall for landing, I thought it was a great feature and would love to have one on my -8.
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 12-13-2007, 05:38 PM
Talking Excellent News
Just the response I was hoping for. Thank you all.
By the way Phil I guess I didn't take enough pictures of your plane at Oshkosh otherwise I wouldn't have had to ask for this advice. Alfa X-ray was definitely one of the nicest 6A's on the field.
Tom Norwood
TMX-O360. Phase 1
Old 12-17-2007, 01:49 AM
Pirkka Pirkka is offline
Another hijack of thread as it seems to be completed.
How did you do that hole (and mechanism) on the lower skin to drain water from upper "sensor"? Everything else in these AOAs seems to be clear but this is something I haven't figured too well...
I found one page where was this hole (which is the easy part) but how exactly do the draining...
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 12-17-2007, 04:53 AM
plehrke's Avatar
Default Draining upper AoA Port
The upper and lower ports are offset spanwise by a few inches. On the lower skin, directly below the upper port, I put a small hole just large enough to put stick a pin (made from one of the hinge pins) up into the wind and push on the drain valve (just a fuel drain) installed on the bottom of the upper port. The water will just run down the pin and out the hole. I did not use the large plunger looking thing supplied with the kit.
Philip
Old 12-17-2007, 06:36 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Pirkka View Post
.......How did you do that hole (and mechanism) on the lower skin to drain water from upper "sensor"?........
The same AOA installed in my -6A includes a spring loaded assembly that slightly protrudes from the lower skin. You simply depress it the same way you would a fuel quick drain. The AOA fitted to the -8 is a slightly different iteration. This one includes a length of pin that is inserted into a small hole the builder drills into the lower wing skin to fish for and reach the upper "sensor." From time to time my -6A has been subjected to rain showers in flight and a couple of driving rains while tied up outside. I have yet to observe any moisture collect in those AOA components.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
