Old 12-12-2007, 05:36 PM
N57 OZ N57 OZ is offline
Default Replacing Nav Lights with LED's
I have to use the Whelan Strobe / Nav lights as I have tip tanks & no room behind to drill mounts for LED assemblies, trouble is I have wired for LED's & the fuse is too small (3A). Does anyone know of a LED with the same fitting that are a direct replacement for the incandescent bulbs. I suppose I could make a replacement using epoxy & the existing lamp but was wondering if there is an off the shelf unit.
Regards
Stephen Reynolds
RV7 N570Z (Reserved)
Finish
Eugene Oregon
London England
Newcastle Australia
Old 12-12-2007, 06:40 PM
jclark jclark is offline
Default Whelen
Whelen now has LED offerings. 71110 Series, I think.
They will be available via Van's.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 12-12-2007, 07:48 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Bulbs vs. assemblies...
James
James... the original question was for a bulb replacement, I believe.
The Whelen lights are an assembly replacement....
http://www.whelen.com/pb/Aviation/LE...ion_Lights.pdf
But they should do the job for a lot more $$$ (or AU $$ or UK Pounds)....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-13-2007, 06:16 AM
Default Yup .. You are right!
gil A
My oversight on that one.
James
James E. Clark
Columbia, SC
APRS
Old 12-13-2007, 07:40 AM
JonJay's Avatar
JonJay JonJay is offline
Default I have them for you
Regards
I have the LED bulbs that will work for you. Send me a pm and I will get them off to you for what I paid for them. I went with the standard inc. bulbs on my install and never tried these. I dont think you will get the performance out of them to meet the FAR's, but they will work.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
