Old 12-12-2007, 12:39 PM
jflyboy jflyboy is offline
Default 8 wings 7 fusalage!!!!
this is probably a retarded question but here goes.. can you put RV-8 wings on a RV-7 fusalage? i found cheap wings but i like the side by side seating of the 7. sorry 8 fans but i'd like to hold my girlfriends hand while i fly. lol i'd still take an 8 thanks for any input. newbie Jay
Old 12-12-2007, 01:47 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default The same
I believe they are the same wings.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-12-2007, 01:52 PM
cjensen's Avatar
cjensen cjensen is offline
They are the same, but the spars are drilled to match the center section of a 7 or 8. That would be my only concern...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 12-12-2007, 01:54 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
The one of the inboard bottom skins on the -8 wings has a NACA cutout on it the backseat vent. I would call up Van's and ask them to be certain.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 12-12-2007, 02:23 PM
Jkkinz's Avatar
Jkkinz Jkkinz is offline
I believe the rear spar attachment is trimmed on the 7 but not on the 8. Like Chad said, the biggest concern is that the spar attachment is match drilled and would pose a problem when changing to the 7. I don't know of any other major differences. Checking with Vans will be your best bet
Jim Kinsey
7A Fuselage
Old 12-12-2007, 02:49 PM
i just got off the phone with vans. scott says that the outboard wing is the same but the spars are drilled differantly so it isn't possible to hook'em up. O well maybe i'll become an 8 guy anyways of course i wonder if you can modify it to work. though messin around with the main wing support isn't my idea of safe. maybe it can be done safely. there is a lot of what if's but the man at vans doesnt recomend it. Jay
