Old 12-11-2007, 10:25 AM
pvalovich pvalovich is offline
Default Vans Light Dimmers
On the road without access to the shop to check this myself - and finalizing panel design with John Stark.
I have two Vans light dimmers in each cockpit (RV-8A). Flood Lights and Inst. Lights.
Does anyone know if the full dim position of those dimmers is actually "Off" - or do I need a separate On-Off switch for each circuit?
Thanks in advance for anyone's quick reply. Another of those cases where hours of panel planning produced a "I have this figured out" feeling - but once again, there's always something else to consider.
Old 12-11-2007, 12:42 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default Connect to NAV lights
Power the dimmers from the NAV light switch. That way off is OFF.
If you are using the little cheapies with a single linear regulator (LM317) you'll find that the min voltage out is about 1.2V. Also, it will dissipate max power with min lights and the heat sinks on some of them are undersized.
I've not seen the others (PWM ones) so can't comment.
John
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
Old 12-11-2007, 02:13 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Keep it on
Having a little trickle voltage to incandescent bulbs makes them last longer. Keeps the filament a little warm and more resistant to vibration. So set the rheostat to min or low will be off. The voltage will be to low to glow but it helps the bulbs. If you want a switch anyway, you can buy rheostats with a SPST switch piggybacked off the pot, click.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 12-11-2007, 03:04 PM
FredMagare FredMagare is offline
John
I ABSOLUTELY love this idea! If it's dark enough to need panel lights, it's dark enough to turn-on your NAV lights!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
