Old 12-09-2007, 06:47 PM
Frank Smidler Frank Smidler is offline
Default AHHHHH - Is stripped 3/8 NPT threads fixable.
I have an 0-360-A1A that was rebuilt several years ago. Up until now it has all looked good with many new parts documented. Today I removed the old, capped off, hose fitting in the accessory case that goes to the in port of the oil cooler (3/8 NPT) and found that it was stripped out. This is like getting a lump of coal in my Christmas stocking. Is this fixable? Does the accessory case have to be removed?
I will probably be calling G&N Aircraft in the morning to see what they can do.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 12-09-2007, 07:00 PM
FrankK90989 FrankK90989 is offline
Default some time
Some time you can cut more threads if the original tap was not set to deep,
run a npt tap in the hole trying to catch the original threads, you can thread almost to the shoulder of the tap and still get a good seal.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 12-09-2007, 07:06 PM
AltonD's Avatar
AltonD AltonD is offline
Pack the tap with a thick grease to catch the shavings.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 12-10-2007, 04:47 AM
mahlon_r mahlon_r is offline
You can install a heli-coil thread insert. You will likely be able to block off the bottom of the port with some sort of plug, do the tapping and heli-coiling and then clean the port and then remove the plug you put in temporarily.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 12-10-2007, 11:12 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Are you sure it's NPT? I thought the oil cooler fittings were straight thread with O-ring. They are on my IO360A3B6D, anyway. It's either a -8 or -10 AN thread.
Heinrich Gerhardt
Old 12-11-2007, 04:59 AM
IO-360-A3B6D is different from an O-360-A1A as far as the accessory housing goes. The oil cooler fittings on an IO-360-A1B6D are o-ringed and the cooler fitting on an O-360-A1A are tapered pipe thread.
Good Luck,
Mahlon
