Old 12-09-2007, 03:33 PM
prkaye prkaye is offline
Default proseal snap bushings?
I was thinking it might be a good idea to use some proseal to set my snap bushings in place so they won't pop out. Is there any reason I should avoid doing this?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 12-09-2007, 03:54 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Added Weight
Added Effort
Added Mess
Its hard enough to get the things flying as it is!
The barbs on the bushings work well. If you must a dab of RTV might add some "belt and suspenders" security.
(I'm more worried about the rudder cables sawing through the bushings!)
Jim Sharkey
Old 12-09-2007, 04:04 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Waste of time... a little dab of silicone will do you.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
