Old 12-09-2007, 04:53 AM
cleve_thompson's Avatar
cleve_thompson cleve_thompson is offline
Default Operating Limitations in Phase II for Experimental aircraft
Are the following limitations for Phase II flight in all Operating Limitations for Experimental Amateur-Built Aircraft, the limitations we have to live by if we fly experimental amateur-built aircraft?
1. ?Except for landings and take-offs, this aircraft may not be operated over densely populated areas or in congested airways.?
2. ?This aircraft is prohibited from operation in congested airways or over densely populated areas unless directed by air traffic control, or unless sufficient altitude is maintained to effect a safe emergency landing in the event of a power unit failure, without hazard to persons or property on the ground.?
------------These restrictions worry me.--------
Cleve Thompson
Waycross, GA
Flying a RV9A with O-320 from KAYS
since Dec 2007 & having a blast
Old 12-09-2007, 05:51 AM
plehrke's Avatar
plehrke plehrke is offline
Default Yes
None of them are actual restrictions to flying in Phase II, though. My home airport is under a Class B airspace and I transition all the time over populated area. It is actually under the 1500 ft ring so I only have 1000ft AGL during the transition. This is perfectly legal with those restriction because of the "Except for Take-off and Landing" phrase. When I am transitioning over densely populated areas it is for take-off and landing purposes. When in a cross country and I over fly densely populated area I am at "sufficient altitude is maintained to effect a safe emergency landing in the event of a power unit failure". If I am in an congested airway I am usually directed there by ATC. So, they are really none restrictions. I think my interprtations are those generally accepted by everyone (and most of the FAA).
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 12-09-2007, 06:23 AM
Those restrictions are obsolete and went away about 7 or 8 years ago. My aircraft's operating limitations were issued in 2001 and did not include those restrictions.
Older homebuilts will have those restrictions, but you can petition the FAA to get the restrictions updated to the modern version without the restrictions.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-09-2007, 07:38 AM
Mitch757 Mitch757 is offline
Default OP Limit Restrictions
Hi Cleve,
I just had an experimental certified last week and your quote was exactly what was printed on my operating limitations.
Mitch Garner
RV-4 flying
PL-4 flying
Old 12-09-2007, 07:55 AM
aviationgeek84's Avatar
aviationgeek84 aviationgeek84 is offline
Default Read this...
Cleve,
I would highly recommend this thread on the topic....
http://www.vansairforce.com/communit...ad.php?t=17261
Casey Hansen (CFII)
EAA Flight Advisor
VAF #1569
Cedar Rapids, Iowa
http://www.mykitlog.com/chansen
I'm on Twitter!
RV-8 - RV-8 Empennage! - N607AG reserved
Old 12-09-2007, 09:16 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Part 91 Genreal Operating and Flight Rules
91.119 Minimum Safe Altitudes: General
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
This FAR aplies to all aircraft operations, including Experimental Category aircraft. Including this restriction in Experimental Operating Limitations is redundant.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 11-16-2009, 02:50 PM
N8RV's Avatar
N8RV N8RV is offline
Default Phase II?
OK, I gotta know ... what IS "Phase II"?
I've searched here on DT for a description, and I've even searched the FARs in a vain attempt to find a definition. I know what Phase I is, but what's Phase II?
Is there a Phase III?
(if this is a stupid question, that's OK ... I ask a TON of 'em!)
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 11-16-2009, 04:15 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Congratulations Don, you are now in Phase II, from which there is no escape.....
There IS no Phase III...
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-16-2009, 04:17 PM
Mel's Avatar
Mel Mel is offline
Phase I is for flight testing.
Phase II is for all operations after phase I is completed and properly documented in the aircraft maintenance records.
There is no Phase III.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-16-2009, 04:19 PM
Mel's Avatar
Mel Mel is offline
The only way to escape Phase II is by going back into Phase I.
Well there is another way, but we don't want to talk about that!
