12-08-2007, 01:42 PM
sailplane tow
Has any one towed a sailplane, glider with there RV?
12-08-2007, 01:45 PM
thats a no no
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
12-08-2007, 03:21 PM
Van put a tow release on the first RV-9, so I guess he did some towing with it? In more recent pictures it seems to have gone so I suppose it didn't work out. I have done a lot of towing, and I'm not sure that an RV would make a good tow plane. I think there would be significant engine cooling problems unless the cowl inlets were made much larger than stock. Bear in mind that on tow you would be flying around 65 or 70kt, where as (my) normal climb speed is 110kt. Sure the stall speed is low enough, and the visibility is good, but would the light weight also make it hard work? I'd stick with a Super Cub/ Husky or Pawnee.
Pete
12-08-2007, 03:30 PM
Senior Curmudgeon
I saw another cool use for a tow hook recently, a friends Aronica without an electrical system.
He just ties the tail down to the hook, starts the engine, climbs in and releases the hook.
Pretty smart these pilot types.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-08-2007, 04:00 PM
Why not?
Why would it be a no-no? I tow with a Cessna 150/150 and I would have to believe a RV-6/7 with a 0360 would do as well. Of course you would have to develop a tow hook attachment.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
12-08-2007, 04:37 PM
Originally Posted by penguin
Van put a tow release on the first RV-9, so I guess he did some towing with it? In more recent pictures it seems to have gone so I suppose it didn't work out. Pete
Van puts a tow hook on all the new models for spin testing. It allows the test pilot to deploy a small chute to recover control if the plane enters a flat spin. The chute is attached to the tow hook and is jetisoned after recovery is made.
Dave
12-08-2007, 04:42 PM
Most experimental ops limitations prohib towing...
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
12-08-2007, 04:43 PM
Yes, it has been done but that was in Germany.
Towing with Experimentals in the US is not allowed. Check the FARS for details.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-09-2007, 06:43 AM
Glider Towing
An RV is way, way too fast for towing. Most of your tow planes are SuperCubs, Scouts, etc. All the tow planes I've experienced tow between 60-70 mph. I've only flown the older steel tube-fabric gliders though. The state-of-the-art glass ships probably could be towed faster.
12-09-2007, 07:26 AM
The back end might just fall off!
Cooling issues aside, the RV in my opinion (and I have done no stress analysis) is much too lightly built to last long as a tug. I have spent a lot of time on both ends of the rope, and while in still air two competent people put little more than 20 lbs force into the rope once the compination is airborne, real world towing is very different. Gliders out of position, and rough air can cause huge jolts. That is why there is a weak link in the rope which I think is usually set around 1000lbs. (It is a while since I looked at that, I might be a bit on the high side.) I think you would soon find yourself with a distorted back end if you were lucky, or otherwise minus a back end. A modern glider with water ballast can easily be heavier than its tow plane.
