What NAV?
The azimuth card on the CDI is not user adjustable. In fact, unless the unit has been dissasembled, it shouldn't be out of alignment at all. Now, if you are hooking the unit to a GNS430/530, you need to get into the GNS setup (turn the unit on while keeping the enter button pressed) and scroll until you find a field that says "CALIBRATE TO 150 DEGREES", then you select the indicator to 150 degrees and press enter on the selected field on the GNS 430 and presto!
Hope this helps. If not, let us know what nav source you have.
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
