Old 12-04-2007, 12:51 PM
db8's Avatar
db8 db8 is offline
Default FM and TV antenna
I don't know if this is an appropriate place to post this question, but a lot of you have probably dealt with the problem I am having, so if any of you have experience with this, it would be great to hear from you via posting here or e-mailing me at cccbuntin@insightbb.com
We just had some hangars built to hangar our RVs (or future RVs as in my case). They are all steel and 40' x 54' and 18' tall. I have run a 22" steel I beam the 40' length (8' high) and will have an area that is 40' x 12' that is kind of like an efficience apartment (loft).
The questions are: the FM (and AM?) reception is absolutely horrible. I have heard various "techniques" to remedy it, but I am almost done with the framing, and want to solve this problem before I go on (ie run wires or antennas). I can put one on the roof as long as it is low profile, but don't know if it's better to just have an inside on. I have done a lot of web-research, but haven't come up with an idea or antenna that seems to have more pros than cons. Was also going to do the same with a TV antenna, since I will not have cable or satellite (just local). Probably go with a HD TV.
Any thoughts or experiences would be greatly appreciated. Thanks a bunch. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 12-04-2007, 01:19 PM
pierre smith's Avatar
Default A signal blocker..
......is what my hangar is also. I went to Radio Shack and bought an FM antenna and mounted it to a length of PVC pipe and u-blots to an upright in the hangar, through the roof overhang and above the roof by three feet. Works really great because of the height. We mounted a TV antenna, not a dish, just regular channels. Works great.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-04-2007, 10:11 PM
n2prise's Avatar
n2prise n2prise is offline
Default Antennas belong outside, not inside.
You can forget about getting a usable signal INSIDE the metal hangar. Like Pierre said, put the antennas outside on the roof. Use RG-6 cable, not RG-59 cable.
I have been in the Cable TV, satellite, and fiber optics communications industry since 1971. Understanding electromagnetic communications and laser communications is how I pay the rent, RV-9A fuel, etc.
Jerry K. Thorne
Built in East Ridge, TN.
Now in Palm Bay, Florida
RV-9A - - N2PZ
www.n2prise.org
Old 12-04-2007, 11:24 PM
PCHunt PCHunt is offline
Default TV in a Hangar?????
I go to the hangar to get AWAY from the radio and TV!!!!!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
