I am the proud 4th owner of RV-8 N247TD, which flies great but is poorly documented. Now that winter has set in I am slowly working my way through all the systems to identify parts, pieces, consumables and replaceables. I removed the right wingtip this weekend to figure out the strobe, taxi/landing and position light systems. The strobe power supply is Aeroflash 152-0007. Here's a picture of the outside of the wingtip with the plastic lens removed.:
Here's the taxi/landing light element:
Here's the position light element, which seems to say "GE193" on it:
and the strobe tube:
I think the strobe flash unit is Aeroflash 073-0270, but don't have any info on the taxi/landing light element and have not been able to find any reference to the GE-193 bulb.
Does anyone in RV-land know what the correct bulb numbers are? O like the looks of the wingtip light system but want to be ready in case a bulb burns out. The bad thing about the system on "TD" is you have to remove the entire wingtip to replace any of the lights!
John
