Old 12-01-2007, 06:42 PM
vbpiper's Avatar
vbpiper vbpiper is offline
Default Access holes
I have cut the access holes in the top forward skin of my -7A, but I am wondering if there are any suggestions for sealing the retaining ring to the underside of the skin, and to form a gasket under the cover panels. I know proseal has been used successfully, but has anyone used any other materials? I am hoping not to have to buy more proseal just for this step.
RV-7A Finish kit
Renewed 8-14
Old 12-01-2007, 06:44 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Try NAPA Ultra Blue RTV - cheap and easy - should work.
Jim Sharkey
Old 12-01-2007, 07:03 PM
kevinh's Avatar
kevinh kevinh is offline
Um - I've heard that RTV anywhere near something you'll want to paint is a recipe for disaster. I'd stick to proseal.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 12-02-2007, 07:16 AM
tc1234c's Avatar
tc1234c tc1234c is offline
I used RTV and painted after a year. The area surrounding access hole looks fine. At least I can not tell there is anything wrong. Before painting, I did lightly sand (2000 wet-dry) around the access hole and clean it with wax and grease remover (not necessary for RTV but for general cleaning).
Ted Chang, VAF #681
2018 Due paid
Old 12-02-2007, 07:57 AM
Mark Castle-Smith's Avatar
Mark Castle-Smith Mark Castle-Smith is offline
Default Access holes gasket
On our RV7 we used neoprene gasket strip. I found a factory in the UK where they made it and sold me a short length in a roll. They make it a variety of thicknesses, some very thin indeed. Works great, totally waterproof (and fuel and oil proof), easy to replace, punch holes in the strip for the screws and creates a very thin seal. Use neoprene glue to bond the 45 degree chamfer in the corners.
Mark Castle-Smith
Finished RV7 and just ordered the RV3 empennage!
www.rv3.moonfruit.com
Old 12-02-2007, 10:46 AM
vbpiper's Avatar
Default RTV
Thanks for the tips. I went ahead and used RTV under the backing rings. Will look for some gasket material for under the covers.
Gotta love these forums.
RV-7A Finish kit
Renewed 8-14
Old 12-02-2007, 04:22 PM
Norman CYYJ Norman CYYJ is offline
Go to an auto-glass shop they have great rubber sealing compound that never hardens that they use when installing windshields. Works great and remains pliable.
