Old 11-30-2007, 09:13 AM
McFly's Avatar
McFly McFly is offline
Default Vertical compass and electromagnetic interference.
I have a vertical compass mounted in my panel. Here is a pic at the bottom of the page. The compass is top center next to the GPS:
http://www.vansairforce.com/communit...+panel&page=11
The heading is influenced by switching various electrical components on and off. The wiring run goes along the bottom of the panel.
I would like to build a shield to surround the compass. Does this have a prayer of working? What would be a good material? Any and all advice welcome.
One a side note: The odometer turned over 100 hours while flying over San Francisco last night while playing tourist. It was beautiful beyond description!!
Hugh
Northern California
RV-7 Flying
Old 11-30-2007, 09:29 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by McFly View Post
I have a vertical compass mounted in my panel..... .I would like to build a shield to surround the compass. Does this have a prayer of working? What would be a good material?......
I purchased this material, haven't installed it yet so cannot comment on its performance.
http://www.aircraftspruce.com/catalo...passshield.php
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-30-2007, 09:46 AM
McFly's Avatar
Thumbs up
Thanks Rick! That was fast!
Hugh
Northern California
RV-7 Flying
Old 11-30-2007, 11:15 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Heated Pitot
My compass is fine with any circuit energized except the pitot heat, and then it thinks it's always pointing NE. Let me know if the ACS stuff works!
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 11-30-2007, 11:21 AM
jmbaute jmbaute is offline
I have some of that material that I purchased for the same reason...but never used it. If you need it, I will be happy to make you a deal to get it out of the shop.
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 11-30-2007, 12:29 PM
McFly's Avatar
Default D'oh
Thanks John but I was too quick on the trigger. I already put the ACS order in.
Hugh
Northern California
RV-7 Flying
Old 11-30-2007, 01:35 PM
RScott RScott is offline
For others who are considering a vertical card compass:
Aviation Consumer had a writeup on VCC's and said that the magnets in them were about 4 times as strong as the magnets in regular compasses, making separation from steel and electrical interference much more important. About half the folks who have tried VCC's have been dissatisfied, and this may be the problem in many cases.
Richard Scott
RV-9A Fuselage
Old 11-30-2007, 03:41 PM
Tony Kirk's Avatar
Tony Kirk Tony Kirk is offline
Default Compass Shield
John,
I'm interested in the compass shield material you have for sale.
My zip code is 43560 if you want to check shipping costs.
Tony Kirk
Van's Aircraft Tech Support
Building RV-7 (N777RV Reserved)
RV-6A N57TK (sold)
First flight 9/5/05...
Sold in 2011 after 725 hours of pure joy!
Old 11-30-2007, 07:42 PM
rfinch rfinch is offline
Wouldn't this block the earth's magnetic field from reaching the compass? Seems you would want to use the shielding material on all the wires and gizmotrons that are generating magnetic fields.
Dawg! Good deal. I've enjoyed some full-moon flights over the Bay in my Aircoupe (which also has a bubble canopy). Hard to beat Northern California for great flying.
Ralph Finch
Davis, N. California
RV-9A QB Log
