Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
  #21
Old 08-03-2012, 06:53 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Originally Posted by rvsxer View Post
EGT spread means nothing. As long as they peak together, as they should with flow-balanced cylinders and nozzles you are good to go. Don't take my word for it, though. Every article I've read on the subject (Aviation Consumer, EAA Sport Aviation, etc.) says just that...
Of course, with the exception of yesterday, this thread is seven years old.
For instance............ from 7/05
Im not even going to use a Subaru, but in honest analysis I find it a better engine than a Lycoming on every count. THIS DOESN'T MEAN THAT IT WILL BE BETTER IN AN AIRCRAFT. That depends on how well it is setup for aircraft. Eggenfellners package is a good one and even the most mechanically challenged (who are capable of building an RV) should have no problems with it.
Some thoughts may have changed, since that was written.
Old 08-03-2012, 09:36 AM
rvsxer rvsxer is offline
I'm sorry, Larry (and Ross). I just had to think awhile about my reply...
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 08-03-2012, 09:40 AM
brian's Avatar
brian brian is offline
Originally Posted by acent05 View Post
Just put deposit on RV-7 with Egg 4cyl (0 Total Time) and MT composite 3 blade prop (150 hrs. TT) I am converting to IO 360 and constant speed and would like to move this whole firewall forward package if you are interested.
I think you'll want to put this in the Classifieds section. It will also be helpful to potential buyers if you specify which Egg 4 cyl (supercharged, non-supercharged, STi), as I'm sure that's the first question they'd be asking.
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
