Old 11-28-2007, 11:12 AM
Camillo Camillo is offline
Default Brake fitting mount on landing gear mount?
I'm installing the brakes lines and I'm not sure how the AN fitting should be installed through the landing gear mount and the bottom skin. There are some options:
1) fitting will "clamp" both bottom skin and ldg. mount;
2) fitting will clamp only the bottom skin;
3) fitting will clamp only the landing mount.
I think the latter is right: in fact, drawing 16 says to open the bottom hole to 5/8'', which should be larger than the fitting (so it will pass throw it and make no grip). In addition, this makes sense thinking at hard landings: if it was linked to the bottom skin, too, it may crack.
On the other side, from dwg. 36/A it seems that the fitting only clamps to the bottom skin (it is true, however, that in such dwg. landing mount is not shown).
Am I right?
Thanks.
You will see how Mike S. did it at the following address (4th photo from the top). I think this is the right way to do.
http://www.my9a.com/finish2.asp
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 11-30-2007, 02:48 AM
Solved. I enlarged bottom skin hole to 5/8''.
Now, AN fitting is only linked to the landing gear mount. I hope this would be OK.
In fact, a lot of builders did the opposite, mounting AN fitting on bottom skin and landing gear mount. Someone put a shim between skin and gear mount to avoid distorting bottom skin when torquing fitting.
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
