Old 11-28-2007, 06:31 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Adapting 1/8" Flare to 1/4" Pipe...
OK, question for folks who may have a bin of AN fittings laying around....
In re-working the panel on Louise's older -6 (serial number 4), the original fuel pressure gauge is coming out, and we're going with an EFIS transducer. the 'ducer has a 1/4" male pipe thread. The current fuel pressure gauge is plumbed off the fitting right at the carb, and comes off with a flex line that looks like it has flare fittings about the size of a primer line - probably 1/8" flare I'd guess. It goes to a bulkhead fitting on the firewall, then there is a brass line that runs from there to the old panel gauge. I'd like to connect the 'ducer to the end of the flex hose, and not add a Van's gauge manifold,. as all the other transducers are already plumbed without one....anyone got an idea of how to connect the two using reasonably standard hardware?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-28-2007, 07:30 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Paul
Paul,
Would one of these work?
http://www.wicksaircraft.com/catalog...289/index.html
or perhaps an AN894-4-3D such as found here?
http://www.bonacoinc.com/an_fittings4.htm
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-28-2007, 07:31 AM
Ironflight's Avatar
Perfect - That'll do it - thanks Rick!
Paul
Paul F. Dye
Old 06-19-2008, 08:05 PM
flion's Avatar
flion flion is offline
I, too, would like to avoid the manifold so need to go from NPT to the Van's hose. Looks like a combination of AN816/822/823 and AN910 would work. Unfortunately I can't find AN910 in steel. Alternatively, is there a single fitting that would go from male NPT to female flare? And why the heck aren't these transducers shipped with flare connectors anyway?
Old 06-20-2008, 08:22 AM
chaskuss chaskuss is offline
Default Look for industrial equivalent
Why not print out the web link Rick supplied you and take it over to your local industrical hydraulic supply house? I'll bet they have it in steel. If you live in a rural area, perhaps an internet search will yield what you what?
Charlie Kuss
PS A quick Google search for AN894-4-3 found it here. Delete the letter D in the part number to specify steel.
http://www.gen-aircraft-fittings.com/
AN894-4-2 was found here
http://www.bandemfg.com/B&EInventory.PDF
Old 06-20-2008, 09:58 AM
frankh's Avatar
frankh frankh is offline
Default 2nd vote
For the local hydraulics emporium...Until you've seen the array of fittings they normally stock you haven't seen anything...This assumes you don't mind steel of course.
If I was doing the airplane again they would be providing every hose and fitting on the airplane, except for the large heavy ones!
Frank
Old 06-20-2008, 03:29 PM
flion's Avatar
Thanks, they also have the AN910. The 894 doesn't work for this application; straight is not the same as NPT. But I can make it work with the AN910 now that I can get it in steel. I appreciate the link.
