Old 11-24-2007, 11:54 PM
asav8tor asav8tor is offline
Default 5V AC instrument lighting
If I use a dropping resistor in series can I use 5VDC on internally lit 5VAC instrument without problems?
Old 11-25-2007, 01:01 AM
gasman gasman is offline
The light will be ok, but the instrument (what is it?) might not like DC.
Old 11-25-2007, 09:28 PM
Altimeter and airspeed. The 5VAC circuit is for lighting only on both.
Old 11-26-2007, 05:47 AM
pilot2512 pilot2512 is offline
this is not the way to go. by practicing a little ohm's law you will find that if 1 bulb burns out the voltage will now go higher. If you put a higher voltage on all the other bulbs, the others will start to burn out faster, depending on the voltage increase. If you use a 5 volt regulator chip instead, you would have a constant voltage no matter the current draw.
Sticky1's Avatar
Sticky1 Sticky1 is offline
Default ac/dc
Thats weird....5 volts ac....R U sure its not 5vdc...?
