Old 11-24-2007, 02:26 PM
TerryWighs TerryWighs is offline
Default Vans wing kit
Just got my confirmation of the wing kit order (RV-8) from Vans. Kit lists is "without center section"...???? Does this center wing section typically come with the fuselage order???? Just wanting to make sure before I sign and return the order.
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 11-24-2007, 02:49 PM
AltonD's Avatar
AltonD AltonD is offline
IIRC, the center section used to be match drilled. It is now jig drilled and ships with the fuselage.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 11-24-2007, 03:18 PM
Thanks Alton....that makes sense.
Fairbanks, Alaska
empennage done
Wings done
Old 11-24-2007, 04:00 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
There was a notice out a few month ago stating the precision drilling was perfected and there was no need to match anymore. I would just call or email Van's to verify.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
